Tube PP amp for subwoofer
I now only have one channel. There is some stereo feeling missing but it is hard to prove indeed. Stil I like it to have two subs for good measure. It also depends a lot on the music. Some disc / lp has hidden sounds in the lows that you only discover with real sub sound
Why two subs ? There is no stereo effect at sub frequencies.
More surface area = less distortion at a given output. I started out with 2x15” in a sealed box. Too heavy to move and looked really big in the room. I moved the same drivers to 2 smaller boxes and not only is it easier to move but the bass quality is much better due to having more sources of bass output which tends to average out the peaks and nulls. I was not expecting such a big improvement in bass quality.
I’m running my 2 subs in mono from 2 channels of a stereo amp. I am crossing over low - maybe 45-50hz with a steep slope so I would not likely benefit much from stereo subs. If your xover is higher and with shallow slopes then you may hear improvements.
There are a handful of efficiency benefits, as well as size. two moderately sized subs is better in some instances than a single larger one. No summing circuit either, so one less stage of manipulation to the signal (if you care about such things) and it can be driven pretty much right from a crossover assuming gain is high enough.
I would take a pair of 10-12" subs over a single 15" any day unless it was very affordable or pretty special.
For me, a Subwoofer is 40Hz and down as the LF cutoff of my towers is 31Hz (I don't bother with one anymore). I'm used to running subs in a car, in the trunk. No stereo effect lost there. Why run 2x100W when you can run 400W bridged? And for me, a "summing" circuit for this is built into my sub crossover, and in the past in cars, I used isolation transformers, and simply shorted left and right.
It’s not a matter of mono/stereo in my case. I am running 2 subs in mono . Power is not an issue for me. What is an issue is achieving flat in room bass response. I have a difficult room for bass. There can easily be 20db difference in level between a peak and a suckout in my room. By having 2 sources of sub bass I am able to optimize their positions for much better frequency response. If you have never measured the response in your room it can be a real shocker to see what you have been listening to. Getting rid of the major peaks can bring huge benefits in bass intelligibility and nuance as well as allowing you to hear past the bass resonances further into the detail and emotional content of the recording. Dips in the response cannot really be dealt with by using EQ. By having multiple subs and your main speakers running full range, if they are capable of handling low bass, you have many sources of bass at different locations in the room which can average out the response at the listening position. It is not easy to set up a system like this due to amplitude and phase interaction between the sources but if you invest the time it can bring big benefits IME. So that is the reason I would prefer in my case to have 2x100w rather than 1x400. The other thing to consider is how much power do you really need and how much can your drivers take before producing high distortion and compression. The Crown amp I use has led power indicators and I have rarely seem the -10db light come on. So that means peaks in the 30w range for very loud music, rock, bass heavy blues etc. I have large drivers in large sealed boxes so the efficiency is relatively high. Small drivers in small boxes would use more power so that is all relative to each room, equipment mix and listening preference.
I get you. I once had a place where the acoustics were so bad that there was no bass in my place but plenty next door. I'm all in favour of multiple subs if that's what's needed for that room, but IMHO they should all run mono from the same amp, or they should be powered subs negating the need for a sub amp in the first place 🙂
Yes choosing a tube amp for subs is not a rational process. But that is what I like about diy and audio. Otherwise I would choose a Sonos and forget about it for the next 10 years
I think I do not need really a lot of watts. If I use a stiff power supply with ample uF I hope to get away with ~30 watts or so. I do have 2 subs with each 12 inch. This design I like because it is well documented and is not very complex. Maybe I can play a bit with the design and class A > B for more power. But first I will need to collect some money, some components and then spend the time
one sub, class D amp works best. clamp the input signal to the sub amp with 2 back to back 5.6v zeners.
11v p-p should drive the amp well into clipping while protecting the input op-amp.
a large power transformer may work well for tube amp output.
2 * 120v to 25v output 300VA
A large power toroidal and some low-impedance sweep tubes is where I would start if building an all-tube subwoofer rig. cross-coupled plate to plate feedback from power to driver tubes, and forget the usual audiphool tube choices. Something like a big 300-500VA for the output from Antek or Triad (or Toroidy, in the EU) and E130L, 6LR6, 6HJ5, or similar tubes. Pete Millet's DCPP amplifier design with a preamplifier stage added, and a suitably overspecified output transformer may be a good starting point. PCB's are available 🙂
100 Watts would be plenty per sub (and easy enough with tubes) if running two at reasonable levels for most use. Party level or bass-head blasting I would go to more efficient subs and parallel the output tubes.
