Hi, at this moment I am using these woofers as subs next to my full range speakers: SW312TU01
Only now I blew one of my Hypex sub-amps (while experimenting with a tube based sub-filter, also burnt one voice-coil) and I am not very happy about this So i am thinking of building sub-amps with tubes. Since these amps will be more robust and repairable for me. These woofers have quite a nice sensitivity and I have 2 woofers in a not too big room
My guess is ~40 watts should be fine. I am thinking of push-pull with Toroidy transformers. is this a suitable design?: OddWatt Audio 5751 SRPP / KT88 Push-Pull Monoblock Tube Amplifier Kits
Or may be a push-pull EL34 since these tubes are cheaper ..? I like a simple design without to much silicon
Sorry to hear about the damage to amp and driver. Do you know what caused the failure? Typically, most people would not use a low power class A tube amp to drive a subwoofer. That's a lot of work and expense to get 40w for a subwoofer. There are lots of easy and reliable solid state solutions out there including used hifi or pro amps.
I use a Crown pro amp to drive 2 15" sealed subs in my main system. Unless you are really set on a tube amp I think you should take a look at pro amps, new or used they offer great value. The Crown I have is a CDI1000 270/500/700 /ch at 8/4/2 ohms. If you use the DSP it can do basic crossover and delay functions as well. Reliable amp with a quiet fan and it has built in protection for any mishaps that may occur. SS amps generally have lower output impedance than tube amps which is an important consideration for a subwoofer amp.
Depending on the size and efficiency your driver/ enclosure setup 40w may not be enough. To get 40w from an oddwatt you would need KT120 or 150 tubes which are expensive and will run hot in class A. If you must have tubes a class AB UL amp would be a better choice from an efficiency standpoint.
The speakers you are using are only 89db... I would suggest at least 100W for any appreciable SPL.
Push Pull KT88 in UL or Tetrode connection would suit better... But for a sub I'd use a class D amp such as this: IRS2092 CLASS D Audio Receiver Power Amplifier AMP Kit 200W MONO Assembled Board | eBay
I'd run the subs in series mono connection.
The tube based filter puts out dc while warming up. I know the UCD modules did not like this but completely forgotten about this. Also I only measured dc output after the filter was warm (and there was almost none) ;-) So now I am working on a delay circuit behind the filter to postpone signal for at least 10 seconds or so
Thanks for the reply. I am really willing to invest in a tube amp because I like tubes and I like the idea ...
This seems like a good options? May be a recommendation?
Hashimoto KT-88 UL Push Pull
http://www.triodedick.com/monobill/monobill schema versterker.GIF
Hot Red PP UL AMP KT 88, von Franz Wichlas
Look to horizontal sweep output types, there are a handful of affordable, high quality ex-soviet types (6P45S, like above, being a good one) that would work well, in addition to the usual television types. It's not unusual to see the output up around 100 watts out of a pair if the output iron is up to snuff. Design with parallel output tubes and stay conservative on the idle biasing for long life, and they should be very reliable long-term.
I wouldn't bother with expensive audio-type tubes for such a use. You can do better for cheaper. Pentode connected, cross coupled feedback.
There is a capacitor on the output but still there is DC at startup? I use this circuit Tube CAD Jounal: Tube-Based Crossovers and Filters
Yes please share the schematic. But I do like very simple circuits and no silicon if possible
Soviet 6P45S (~PL519) sweep tube is very efficient.
I built this some years ago. It gives clean 170 W out.
Try lowering the 1M resistor on the output to 47k-100k. A 1uF cap will take time to charge up through 1M. Or, as Lingwendil said, short the cap to ground through a time delay relay circuit. One of these per channel set at the longest delay is a cheap and easy way to implement: NE555 DC 12V Delay Relay shield Timer Switch Adjustable Module 0 To 10 Second | eBay
...the elephant in the room is what OPT are you going to use?
Good low frequency performance require high primary inductance. The higher the better.
The frequency response of the amplifier can be very limited from high end. This makes the design easier.
I have my eyes one something from Toroidy. I have good experience with their power transformers and chokes. But not yet with the OPTs. And their products are relatively payable
And I am buidling a 6V based relay because I do not have 12V readily at hand in the power supply
Those Ebay circuits I already have and they are fine although only for 1 channel per print and up to 11 sec. max. (I measured)
What is?
Thanks, did not realize this
What is?
Like this. Bonus is you only a mono amplifier (single channel with L+R summed output)
- Tubes / Valves
- Tube PP amp for subwoofer
