SY --
One of the people who worked on Jim Williams (williams was the editor) "The Art of Analog Design" remarked on how Williams convinced his father to purchase a Philbrick OPAMP for him -- back in the days when $250 would buy several cases of Margaux, or a Hallicrafters SR-150.
On the subject,
http://headwize.com/projects/showfile.php?file=opamp_prj.htm
has a pretty comprehensive reference list.
The article itself, on tubes and opamps, is good reading too.
- - Rocky
- - Rocky
tlf9999 said:since our amps are for the most part op-amps, do those analog computers / op-amps used in missiles for example suffer from the same mishaps of our amps?
for example, what is the impact of accuracy from first-cycle distortion? or back-EMF? or ???
No, and no. Single ended and push pull amps are rarely of the same sort as an op-amp. For instance, gain is controlled and often, loop NFB is low (or not used at all). Op-amps work entirely by NFB, ideally having gain approach infinity (such that very nearly zero signal voltage appearing across the terminals produces an infinite output voltage). Also, since gain is so high, distortion is corrected by using ohmic resistors to define gain and thus distortion.
Tim
I have a doubt...
I've read the article on headwize regarding tube opamps, and I recall reading somewhere (maybe in this forum) that the usage of negative feedback in tube designs reduced the gap to solid-state designs in terms of sound. So, if I were to use one of those tube opamp designs configured for a gain of 10dB, or something like that, as a line stage would I lose the benefits of using tubes in the first place?
Sorry if this is a stupid question, but I don't know much about valves...
Devius said:I have a doubt...
In the sense that you'll have lower distortion and source impedance, yes, it will sound closer to good solid state.
Devious opens:
"I've read the article on headwize regarding tube opamps, and I recall reading somewhere (maybe in this forum) that the usage of negative feedback in tube designs reduced the gap to solid-state designs in terms of sound. So, if I were to use one of those tube opamp designs configured for a gain of 10dB, or something like that, as a line stage would I lose the benefits of using tubes in the first place?"
SY counters:
"In the sense that you'll have lower distortion and source impedance, yes, it will sound closer to good solid state."
audio aikido?
SY counters:
audio aikido?
SY:
So I guess you're saying it should give good results. I was interested in those tube opamp designs since they allow lower gains to be set more easily without changing tubes.
"In the sense that you'll have lower distortion and source impedance, it will sound closer to my cathode follower preamp."
- Tubes / Valves
- Tube op amps
