just another update, fortunately i've got from a friend another shunt HV board made by Quang Hao (thanks Piero7), populated and connected the board in place it works perfectly, with a dummy load (6,8k 10W resistor), changed again the board with the Oliver's one and dummy load again Vout=Vin-2V
for sure i'm doing something wrong, please Oliver and Salas check the pics posted before if everything is in the right place and orientation
HV-Shunt Module schematics
i did, tried a third board by Oliver, same result, with R1=33 Vout=Vin-0.8v
i quit.. 😡
i can't figure out what's wrong.. quanghao boards works like a charm in the same dac..
i quit.. 😡
of course also removed the heater lifter... please forgive me... are you perfectly sure that you have the desired voltage drop between input and output in your board with everything connected? could you check? because it is very strange for me....
Sure! Stable 170V input and 150V output from my transformer on a 0,1A Tap.
no... i tried first the other boards before starting desoldering....
i'll start with that one and then the smaller ones...
Tfan69
Double Check everything! From the exact name of the transistors (made this mistake myself once - Salas spotted it!
) to the soldering (on both sides, particularly the one where it meets the trace) to the resistor values (mixing R & K for example).
Hello Oliver, there is a preferred point to get the ground line on the tubeizator to be connected to the star ground of the chassis? how do you ground yours?
thanks
I find that the "-" trace on the removed capacitor is the perfect place to put the shunt module GND.
a little update: just swapped the boards, same exact results, adjusting the trimmer result in the same behaviour (Vin=Vout-2v approx.)
any ideas??? i followed exactly the print on the pcb for components positioning.. i'll post a close up, perhaps i'm missing something...
edit: added pics
Not why you're having problems, but you'll need some heatsink paste on those transistors.
used already the "-" 😉, i added thermal paste 😛
i read:
IRF840
IRF9610
MJE350
K170GR
here's my order from mouser
i read:
IRF840
IRF9610
MJE350
K170GR
Mouser No: 757-2SK170GRF
Mfr. #: 2SK170-GR(F)
Desc.: JFET N CHANNEL JFET Vds 10V Idss 3mA
4 € 0,883 € 3,53
4 Shipped 08/10/2010 24676674
Mouser No: 511-MJE350
Mfr. #: MJE350
Desc.: Bipolar Power PNP Medium Power
4 € 0,50 € 2,00
Mouser No: 844-IRF840PBF
Mfr. #: IRF840PBF
Desc.: MOSFET Power N-Chan 500V 8.0 Amp
4 € 2,38 € 9,52
Mouser No: 844-IRF9610PBF
Mfr. #: IRF9610PBF
Desc.: MOSFET Power P-Chan 200V 1.8 Amp
4 € 1,42 € 5,68
- Group Buys
- Tube-I-zator Professional PCB
