Tube-I-zator Professional PCB
Tube-I-zator Pre-Orders:
Cris H. - 1x (please change to your nickname yourself!)
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
HV-Shunt Module Pre-Order for 2nd Batch:
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous 2x
It must be stable ~170VDC if you come from a 150VAC tap of your transformer.
Oliver,
Is it okay if I have 220VDC or do I have to reduce it first to 170VDV ? Also, may I know the resistor value of your RK and I/V on your Tube-I-Zator.
Thanks,
Joe
Hi Joe,
you must measure the input voltage with the reg. (~35mA load).
If you have with the load 220VDC input voltage, i think you must use a bigger sink!
The resistor values for a 6N2P/12AX7 is Rk=200R.
The R I/V depends on the DAC Chip you would like to use. If it is the TDA1541A i would recommend 56R with one DAC Chip.
Oliver, thank you much for your help.
I'll just reduce the B1 voltage with resistor as I don't want to change the heat sink size. What is the minimum input voltage for the HV shunt?
I have the Buffalo II DAC. I'll check the older thread, maybe a couple of Buf II owner/posters mentioned what R I/V value they are using.
Thanks,
Joe
Thanks,
Joe
Salas recommend a Vin/Vout diff. of minimum 15-20V.
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
Crusty 1x
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous 2x
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 - 1x
morpheous - 1x
neoinc - 1x
Crusty - 1x
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous - 2x
ksnider1 - 1x
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 - 1x
morpheous - 1x
neoinc - 1x
Crusty - 1x
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous - 2x
ksnider1 - 1x
ipolyakov - 2x
Oliver,
The measured 220V is without the load. I also tried just after the rectifier, it's also 220V.
Thanks,
Joe
Hi Joe,
your values are absolute normal and correct.
As you see on the following snapshot from the PSU Designer, there are the same values.
If i add the ~35mA load from the shunt, the voltage drops to the recommended 170VDC input voltage.
Best regards,
Oliver
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 - 1x
morpheous - 1x
neoinc - 1x
Crusty - 1x
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous - 2x
ksnider1 - 1x
ipolyakov - 2x
savvas - 2x
Hello Oliver,
i have a strange behaviour of the shunt: it is supposed that i have a Vin and a Vout, let's say that i have 240v Vin, if i adjust the trimmer to have Vout=220 the Vin drops down and Vout is always approx Vin-2v
any ideas?
