Tube DAC-CS8412+TDA1541A
Hello to All!
I wonder what would be the best option:
I have 4x18[v] secondary transformer to power mentioned chips and small dilemma, should I share from one PSU -5V and -15V for TDA1541A and make separate PSUs for +5v, +5v for CS8412 and +5v for TDA1541A?
One more question, as this going to be my first approach to DAC-built, where
to place connection between chassis and ground, make star grounding
from each PSU?
Thanks in advance
slav
I'd say you'd be wanting lower voltage transformers for the +/-5v rails. I usually use 9v for these. Dropping from 18v (which will be 25vpost rectifier) will cause the regulators to get really hot. ALso, its worth considering that more seperation in rails is better. In my players I use sepreated regs for each device supplied and where possible seperate complete psu's including the transformer windings.
