Evening all, need some advice plse.
Currently I use an Integra 30.2 as distribution point, the pre amp out on the Integra is only about 215mV. I use a NAD monitor 1000 preamp to amplify the small AVR output signal to drive a Slewmaster power amp. It sounds OK but I have a tube buffer that I want to incorporate for better possible results. Should I connect it between the AVR and preamp or between the preamp and poweramp for the best outcome. The buffer circuit is from uncle Hugh Dean.
Much appreciated.
Jan
Much appreciated.
Jan
