It's a crapshoot.
I heard a nice sounding tubeamp from China that was $200 landed cost at the 2006 diyCascadia. Was it great? Heck no. Was it worth $200? Absolutely! 😀
Then I've heard $1,500 Shanling's magazines rave about.
I'd offer $20 for it
Then use its parts for something else.
Caveat Emptor!
Caveat Emptor!
These amplifiers are cheaps but I think that with an upgrade they can play very better... now I look for only the schematics. 😀
I have found the schematics of Dynavox VR-70E
at this site : http://www.krauhs.net/documents/dynavox.html
(Schematics = Schaltbild)
I try to find the Chinese factory website and/or schematics of model CST80..CST160
Gold_xyz,
look on my homepage, there are two versions of the schematics of Dynavox VR-70E .
first the original one
second the modified one
http://www.verruecktedinge.de/roehrentechnik/Dynavox_Schaltplan.html
greetings Bernd 🙂
greetings Bernd 🙂
I've kind of had my eye on this one
http://cgi.ebay.com/AUDIOROMY-FU29-...oryZ3280QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Aside from the output terminals it looks pretty sweet and would probably be worth the cash. Ethically speaking, I don't think I could buy Chinese goods if avoidable.
Jeb-D. said:I've kind of had my eye on this one
I'm showing $192 shipping to my addy - get it from their website - It will cost $20 less USD and shipping is FREE!
http://www.hi-end.on9mart.com/cart/AR_FU29.html
Re: Slightly OT
It is an Asian clone of the popular 829B, a common VHF transmitting tube from the war. It was also used as a radar modulator known as a 3E29 in selected batches that could handle the high peak pulse voltages. Two 6L6`s basically in one hard glass envelope but sharing a common screen grid connection.
poynton said:What is a FU29 ?
It looks like my avatar.
Andy
FU29?
Hi everyone!
This tube looks exactly like russian double beam tetrode GU29 (cyrillic lettering is slightly different).
Here is the datasheet: http://tdsl.duncanamps.com/pdf/gu29.pdf
Best regards!
Hi everyone!
Best regards!
Geek said:
Anyone any ideas on the output TX ?
Andy
Before you buy this - get the schematic and how to bias the amp. There are two pots for each channel. There's a 6N1 and 6N2 in each channel as drivers. and tell them youwant to see the schematic before you buy else NO DEAL.
The FU29 is the Chinese label for the Russian equivalent GU29. Here we call it the 829B or the 3E29.
Oh - make sure you get them to wire it for US voltage - the power transformer is dual voltage.
Bob
Bob
Unfortunately it seems that the schematics provided by the seller isn't reflected by what is in the amplifier.
Read this touching story if you dare:
http://www.lampizator.eu/AMPLIFIERS/CHINA/SET triode amplifier Music Angel 845 Hong Kong.html
The Music Angel example may or may not apply to this amp. I'd like to see the schematic for this 829B amp. It could be paralleled SE or push-pull depending on the circuit and the transformer. I suspect PP since the output is higher than expected with SE.
I would really like to see a schematic.
I have sent emails to the ebay sellers asking for a schematic - may be if others here on this forum were to also ask for a schematic - then they would get the message: their amps won't sell without a schematic and biasing instructions.
Bob
Bob
Re: Dynavox VR70
Viel Dankesehr ! 😀
Very Good Schematics, in 1940 they not have a large capactor (or it was not cheap)
for anode supply then they used a pi-greek filter with big inducitor.
Today it is very better to use a big capacitors (IMHO)
...I have redraw some schematics 🙂
(only redraw - not tested - not build
Bierbauch2000 said:Hi,
pleas have a look on my websites
I have tuned an Dynavox so that he has a better curve linearity
ther are not much things to
here is a link to ma homepage (sorry it's only in german)
the modifications are in blue in the cuircuit.
http://www.retro-optonica.de/Dynavox/DynavoxSchaltplan.htm
http://www.retro-optonica.de/Dynavox/Dynavox.htm
i hope you can understand what i have done.
Kind regards from Odenthal / Germany
Bierbauch2000
Viel Dankesehr ! 😀
Hi, did you ever get the schematic for the CST-80 tube amp? I am in need of a schematic. I have an OR.M CST-80 and one channel is weaker than the other. Thanks
can you just tell me the type of pilot lamp and phase shifter lamp ?
I ask you this because your amp looks like a lot of old amp, it is possible that the scheme is the same as several amp sold for years under different brand.
of the kind
Cochet AL2
of the kind
Cochet AL2
I have built quality valve mixers and valve amps and tried to sell them on ebay.
In the end I was selling them for less than components cost just to move them on.
Napovo-
Instead of 'bringing back to life' this old discussion (from 11 years ago), you might get more up-to-date info by starting a new discussion thread: "Schematic for Chinese CST-80?" or something like that.
But you did get some answers here, so perhaps you will be OK. 🙂
- Tubes / Valves
- Tube amps from eBay (China)
