The calculation is even easier: Zprim = U²/P, where U is the nominal line voltage, here 100 V, and P is the power labelled at the terminal.
Anyway, the Alltronics M-1115 appears to be somewhat whimpy. Here's a specs list of Omnitronic line matching transformers which might be more up to task, especially in twin-coupled designs.
Best regards!
Best regards!
No, the CT is labelled 25 W if one uses the COM and the 6.25 W terminals as the ends.
Best regards!
Best regards!
Just my opinions:
Many want to build with parts employing them in a circuit that they were not made to work in, nor designed for that kind of application.
I see 3 reasons for this:
It is a challenge to use the part that way. Just like climbing K2, the number 2 mountain.
To save money $$$
The Original Poster has some parts, and does not know what to do with them. So, they find a way to use them anyway (even if they will not work very good there).
I am reminded of being on a US Naval Destroyer in the middle of the Pacific Ocean, without proper repair parts.
That is why I would use parts improperly . . . to get the equipment running again, and to get the officers off my back.
Most tube amplifier designers and builders are not subject to those US Naval conditions; the tube amplifier designers/builders can get the proper parts.
Just stop drinking those $5 cups of Coffee every day. 30 Days = $150, enough for a pair of inexpensive output transformers that were actually designed for Single Ended, or designed for Push Pull.
Have Fun designing, building, and listening!
To save money $$$
