Over the last year I have done research to find a wide variety of information for myself on DIY tube amps and I’ve decided to share these web urls with you. I hope that maybe one or two of these links will help you find the right project or kit to help you with your next project.
http://www.diytube.com/phpBB2/index.php
http://www.tubes4hifi.com/pre3.htm
http://www.pacificvalve.us/LiTeGallery.html
http://www.lite8.com/
http://vocativeaudio.com/
http://bterry65.tripod.com/id20.htm
http://www.affordablevalvecompany.com/products.htm
http://www.laaudio.com.tw/
http://www.sinfonia.or.jp/~audiocol/
http://www.elekit.co.jp/english/catalog/srch_result.php?ssi=1
http://www.cnamusic.com/elekit/default.htm
http://digilander.libero.it/essentialaudio/hybrid_pcb&kits.htm
http://eshop.diyclub.biz/index.php?cPath=205_149_106
http://www.tubezone.us/servlet/StoreFront
http://www.sparetimegizmos.com/Hardware/Stereo_6t9.htm
http://www.triodeelectronics.com/mk3boardsparts.html
http://store.qkits.com/
http://web.mac.com/calhoun/PCB/Firefly_PCB.html
http://www.pmillett.com/index.html
http://glass-ware.stores.yahoo.net/aikamocdualp.html
http://www.thetunerguy.com/new_radii.html
http://www.dogstar.dantimax.dk/tubestuf/index.htm
http://gabevee.tripod.com/mag1515.html
http://www.t-linespeakers.org/tubes/SEP_50EH5.html
http://secure.oatleyelectronics.com...d=256&osCsid=e980c00001bb7298638377c93f7948a8
http://www.ys-audio.com/ys-audio_eng.htm
http://www.iol.ie/~waltonaudio/mk1schematic.html
http://www.angela.com/
http://www.geocities.com/rjm003.geo/rjmaudio/diy_fire.html
http://www.the-planet.org/audio.html
http://cognitivevent.com/images/6H30pi-12B4_jul02.gif
http://www.audiodesignguide.com/my/index.html#MY_OTL
http://hem.passagen.se/ebcpecz/Tube/Headphone/headphone.html
http://www.audiodesignguide.com/otl/
http://www.euronet.nl/~mgw/links/nl_index_body.html
http://www.audiohobbyist.com/diyparts/parts/kit/6ew7.htm
http://www.dynakitparts.com/store/company.aspx
http://www.eddiecurrent.com/
http://www.vellemanusa.com/us/enu/product/view/?id=350612
http://www.mei-xing.com/English/e-zycp.htm
http://www.pjrc.com/tech/mp3/
http://www.edcorusa.com/products/xamplifiers.html
The last link is a complete DIY kit for the budget minded and seems to be a promising small amp. $105.99
1. Tube : EL84(or 6BQ5) x 2 , 12AX7(or ECC83) x 1
2. Output Power : 2 X 2.0 Wrms (at 8 ohm load ) , Class A , Single end
3. Output impedance : 8 ohm standard (option 4 ohm ,16 ohm)
4. Feedback method : PK or NFB (selectable)
5. Input sensitivity : 0.5 Vrms (at PK) , 0.65 Vrms (at NFB)
6. Power source voltage : AC110/220, 50/60Hz
http://www.tubeamp.idv.tw/en/index.php
http://www.tubeamp.idv.tw/en/image/arx-el84-2.jpg[/IMG]
Here are two from my site: DIY Tube Vacuum Tube Audio Projects and S-5 Electronics Tube Amplifier Kits.
Here are some other great sites you missed:
http://www.angelfire.com/electronic/funwithtubes/
http://www.vt52.com/
http://tdsl.duncanamps.com/index.php
http://www.valvewizard.co.uk/
http://www.turneraudio.com.au/
Geek said:
Yes we do! To much time researching and not enough time making! LOL!
Here is one I found a couple of days ago and its real cheap!
Vacuum Tube Amplifier kit powered by 12 volts!
PRICE $37.00 PLUS S&H & INS IN US.
http://www.pastimeprojects.com/
The chassis sucks however who cares at $37 dollars!
Also Decware has a new kit out as well the ZEN TRIODE AMP at $299.00
http://www.decware.com/newsite/SE84CDIY.htm
http://www.decware.com/newsite/images/SE84CKITsm.jpg[/IMG]
LOL! I find that actually cute - the "romance" of 40's and 50's DIY for the younger crowd
http://frank.pocnet.net/
http://www.nj7p.org/Tube.php
http://208.190.133.201/tubes/
http://www.wps.com/archives/tube-datasheets/
http://www.westernelectric.com/support/we_spec_sheets.html
Perhaps it should be appended to
"On Line Tube Learning for newbies...."
http://www.diyaudio.com/forums/showthread.php?s=&threadid=38278
Aw, heck, I'll throw mine in (no kits, just articles and plans).
www.syclotron.com
And Kevin Kennedy's, too:
http://www.kta-hifi.net/
www.syclotron.com
I'll add my links page as well: http://www.audiophool.cjb.net/Techno.html
Well, I guess if we are throwing in our own, I'll add mine to the mix:
http://diyaudio.ecp.cc
Also, I didn't see Tubelab represented
http://www.tubelab.com/
Joined 2008
Supplier
Hello !
Greetings from Germany !
A must have adress:
http://www.askjanfirst.de/eindex.htm
Best regards
Lufton
Hello !
A must have adress:
Best regards
Lufton
- Tubes / Valves
- Tube Amp Links
