tube amp kit on 230 v???
Please avoid multiple posting in the future. Hopefully, the moderators will purge the duplicate.
In addition to the voltage difference, the AC mains in North America are 60 Hz., not the 50 Hz. found in Europe. Inexpensive power transformers designed for use at 60 Hz. may overheat if used with 50 Hz. current. Before you spend any money make sure that the low priced kit's power trafo can work at 50 Hz.
Assuming 50 Hz. house current is OK, the voltage difference can be dealt with by acquiring a step down autotransformer.
BTW, ask the distributor if a "universal" power trafo is available for the kit. Such a trafo will increase the kit's cost, but the increase rates to be less than the cost of an autotransformer.
Size matters!
Judging by the photographs, the KECL82 amplifier has larger output transformers, and that's a good thing. Also, the power supply is rather better, having a CLC filter. It should make a good beginner's kit.
