Reading the BH EL84 thread and also skimmed a bit of Bandersnatch threads. I also looked at the Tubelab SPP EL84 product and some of the information looked like it might work for me. Needs someone with better understanding to give a verdict.
Tubelab SPP advantages - simple, no semiconductors (ultimate simplicity), lots of builds, good support, relatively easy to build without a PCB
BH advantages - probably marginally better performance if OPTs are less than ideal, lots of builds, good support in build threads.
minor disadvantage - Off-PCB builds more complex with the additional sub-circuits involved - perhaps best done as a mix of PCB for the CCS circuits and the rest P2P, needs a negative rail for the ccs (minor issue)
Toss a coin and make a choice. Both have good reputations
I contacted Doug (Bandersnatch). Let's wait and see what he comes up with.
FWIW, it seems clear to me is that several very reasonable options are coming to the fore.
I have read the first 60 pages of the EL84 thread and found 2 references that some people have built with the 6.6kohm rather than the 8kohm. Ian also mentioned that the 1620 6.6kohm can be used, hence I do believe the 1626 6.6kohm can be used also. I will keep browsing the thread. Any word from Doug B.
MM
MM
