I need to sort out a drive belt for my DIY TT. It will run around the outside of the platter and the motor pully will be about 39-40mm diameter. Total length works out at about 990mm.
The closest I have found is 950 x 6.5mm and I am assuming that this is going to put to much strain on the motor bearings.
Has any one got any ideas? Could I make a round section belt? The motor pully is a deecent size so I presume it would not put to much strain on a glued joint.
I have read about making them out of recording tape, but I dont want to go to the hassle of spring mounting the motor on a sled. Is this always nessesary when useing tape?
Any advice greatfully received as it has me a little stumped at the moment. I would prefer to source parts in the UK if possible.
Paul.
Paul.
Couple of winds of Dental Floss, unwaxed🙂 is claimed by some to be an upgrade over OEM rubber belts.. easy enouigh to try.
No, you do not need any sled/lateral adjustment mechanism, providing your motor housing is massive enough (the more the better, but about 3-5 kg is OK), to rely solely upon friction force between it and underlying shelf. It works for every Teres-like TT.I have read about making them out of recording tape, but I dont want to go to the hassle of spring mounting the motor on a sled. Is this always nessesary when useing tape?
Thanks guy's, I will give both a try.
How do you join the dental floss, cant say as I have ever seen any nevermind used it!
Paul.
Paul.
