Wondering if anyone has put terminal blocks, like those used in the SSE, on the TSE. The holes don't look spaced correctly to fit the 2 and 3 terminal blocks... Is there a single terminal block that could be used?
Maybe this: Amazon.com: 20A 2-12 Way Electrical Screw Terminal Block Connector 2: Electronics
Kaos: The Euro-style terminal block that you linked to is not a PCB mount (there are no pins to stick through the PCB). You stick wires in either end and screw down to connect together.
