The TSE calls for 510 ohm in the cathode resistor and divider output for the 5V vreg. Somehow the Mouser order came with 5.1K instead of 510. Since the driver is run with a CCS, can a 470 ohm be used in the cathode resistor spot?
I would assume likewise in the Vreg for a 1:1 divider ratio?
