TSE 11 has a speaker inside
A strange occurrence for my TSE 11, I just finished the build after approx 8 hours or so, the source plays inside the chassis as if it has a speaker, it happens every time it is turned on, it also plays normally through speakers w/o any noise whatsoever, it is affected by the volume controls, which are Goldpoint, if they are at 50% then I cannot hear the inside speaker. Has anyone experienced this?
I sent the OP an email explaining that this phenomenon is usually caused by the OPT, especially in an SE application. It said:
It is not uncommon for the output transformers to make sound. They have all the same components as a speaker, a coil of wire, some magnetism created by the DC current in the windings, and a metal housing that can vibrate in that magnetic field. Sometimes this effect can be reduced by tightening the bolts that hold the transformers together. Removing the bolts or taking a SE output transformer apart is not recommended as some do not use a spacer to establish the gap required for proper operation.
Often these vibrations are transferred to the chassis which acts as a "speaker cone" making them louder. Sometimes a rubber spacer or pad between the transformer and the chassis will reduce this effect.
Tubes do occasionally ring at a nearly constant pitch, but some OPT's play music that's recognizable.
I have never heard a push pull OPT sing, but it is not uncommon with SE transformers. I have a pair of the large Edcors. One is quite loud from about 200 Hz to just over 1 KHz. The other is much quieter, but still makes some sound. Neither were mounted and laying them on their side with one end bell on the work bench makes them quieter.
It is not ringing from tubes or components; it is music like an iPhone inside the cabinet. It is loud enough to hear from a few feet away; the volume adjusts with the v/c . The transformers are SE Hashimoto mounted on rubber mounts. They were also mounted on a different amp prior to this one, which did not have this issue. The difference may be that the other amp's chassis was SS, and this one is aluminum.
I think you should try to identify what it is where the sound emanates. Staring into the box probably won't give you a clue.
In the days we would put the end of the handle of a large screwdriver against our ear and then touch several points in the unit with the tip. You could easily find the loudest point/part.
BTW, works also for car engines 😎
Jan
