TS parameters for a midwoofer used as Passive Radiator
Hello, I need to simulate a loudspeaker using a second identical not-connected midwoofer as a Passive Radiator (PR). I could use UNIBOX for example, or other software.
(I will maitain the drive whole complete, i.e with its magnet)
In the software can I input the PR parameters in the Passive radiator section, using the same TS parameters I find in the datasheet of the midwoofer?
In particular, is correct:
the PR free air resonance frequency Fsp = Fs;
Mechanical mass of PR diaphragm Mmp = mms;
Q of driver at Fsp considering mechanical losses only =QTS
Xpmax Peak linear PR excursion = maximum peak linear excursion vibration Xlin
where Fs, mms and QTS and Xlin are the TS parameters published by the manufacturer of the not-connected driver used as Passive Radiator?
