Hello
Could someone help me find T&S parameters for the NX750P YORKVILLE bass speaker ? I got a free pair of these (without the class D amps) and I'd like to using the 15" bass speaker in a correctly calculated bass-reflex wood cabinet, not for real HiFi purpose, but for a clean and private PA system.
Yorkville part number should be 7410
Official Yorkville documents shows no info about T&S parameters.
If nobody responds you could take the driver out and make pictures from all sides. It is more likely somebody recognises the driver from seeing a picture.
T&S parameters for Yorkville speaker NX750P
Hello Djim, thank you for you advice, so I join 3 picts of this bass speaker from this Yorkville NX750p.May be someone knows the manufacturer of knows Yorkville EOM. Replacement speaker should be 7410 (Yorkville part#) but tag said 15/306 - 8 which I presume means :
15 inches : diameter of aluminum frame
306 mm : diameter of paper cone
8 Ohms.
No big help isn't it ? Yorkville says it has a Neomydium magnet.
So.. Have a look and try to recognize this speaker... Is it Chinese or US made ?
(Even in China they have Thiele and Small parameter do they ?)
Many Thanks anyway
FrenchGuy
8 Ohms.
Many Thanks anyway
FrenchGuy
Bingo ? It looks like it... let's wait for few days to see is other answers are coming..
If it's a B&C, we should get the T&S parameters quite easy I guess ?
looks pretty damn similar to me! but thats just going by looks....i'm guessing you don't have anyone in the area that has equipment to measure the driver for you?
- Subwoofers
- TS parameter for 15" Yorkville 7410 ?
