Hello,
I have done some TS measurement with a few different tools: WT3 and Limp mostly.
The results I obtained showed some disparities and I am not sure what is best to believe...
I would like to know, from your experience, what is your method of TS measurements, what are your tricks...
Try measuring some known impedances, like an inductor, resistor, and capacitor. If those can't be read accurately, then you have little hope of measuring a woofer properly.
I've used the signal generator + DMM method plus added mass. And, the IMP/M which was a heck of a lot quicker, although it takes more pieces and wires and time to set up. (Laptop, IMP/M box, power amplifier...) (The mass was a piece of solder, measured accurately in a chemistry lab.)
I suggest building an interface box with a built-in gainclone power amp (or two), buffer amplifiers, reference resistor, and switching as required to allow doing various tests using Speaker Workshop (or other software). Including a USB sound device, like a Behringer UCA202 (with better power supply filtering, preferably), would make it very convenient.
I don't know for sure how accurate my measurements were, but they were usually reasonably close to the numbers in the specifications. Except maybe with some Radio Shack mini-woofers.
