Here's the circuit of an amplifier where the speaker is used as a microphone:
[IMGDEAD]https://inus.azureedge.net/temp/Speaker%20preamp%20draft.png?sv=2018-03-28&si=ro&sr=b&sig=fcxsYWGTTFe0BkcLc7lyhrBly6hyDeKIq7AgjWpYUoo%3D[/IMGDEAD]
And this is my TINA simulation:
[IMGDEAD]https://inus.azureedge.net/temp/speaker%20preamp%20tina.JPG?sv=2018-03-28&si=ro&sr=b&sig=OwdBrkWQtSS4smVmiVmfCI9a6CtQvwtec216%2BRtk1jE%3D[/IMGDEAD]
1) I'm not even sure I understood the circuit right. Especially, regarding split voltage source.
2) When I check the simulation in TinaTI is gives me these errors:
The .TSC file is here in case you want to use it.
Thank you!
I do not understand these errors, can someone please explain what's wrong with it?- Pin Prim1 of Ideal Transformer TR1 is floating (This node will be grounded)
- Pin Prim1 of Ideal Transformer TR1 is floating (This node will be grounded): Pin 2 of Loud-speaker SP1 is floating (This node will be grounded)
- Pin Prem2 of Ideal Transformer TR1 is floating
- Pin Prem2 of Ideal Transformer TR1 is floating: Pin 1 of Loud-speaker SP1 is floating
Thank you!
