Hi all, i tried to simulate the response of the stasys x cab, but after entering the data the output graph is a nigthmare. There's something I'm doing wrong in this scrip?
System 'stasys x'
Def_Driver '18g50'
Sd=1320cm2
fs=40Hz
Qes=0.334
Qms=12.05
Vas=212L
Re=6.1ohm
Le=2mH
Driver Def='18g50'
Node=1=0=3=4
Enclosure 'E1'
Node=3
Vb=121.6L
Lb=70cm
Duct 'D1' Node=3=5
SD=638cm2 Len=15cm
Waveguide 'W1'
Node=4=5
STh=0.1cm2
SMo=667cm2
Len=52cm
Conical
Waveguide 'W2'
Node=5=6
STh=771.4cm2
SMo=1258.6cm2
Len=44cm
Conical
Waveguide 'W3'
Node=6=7
STh=1258.6cm2
SMo=3021.8cm2
Len=26.5cm
Conical
Duct 'D1' Node=3=8
SD=158.4cm2 Len=38.3cm
Radiator 'RS1'
Node=7
SD=3021.8cm2
Radiator 'RS2'
Node=8
SD=158.4cm2
thanks, sorry for my english.
System 'stasys x'
Def_Driver '18g50'
Sd=1320cm2
fs=40Hz
Qes=0.334
Qms=12.05
Vas=212L
Re=6.1ohm
Le=2mH
Driver Def='18g50'
Node=1=0=3=4
Enclosure 'E1'
Node=3
Vb=121.6L
Lb=70cm
Duct 'D1' Node=3=5
SD=638cm2 Len=15cm
Waveguide 'W1'
Node=4=5
STh=0.1cm2
SMo=667cm2
Len=52cm
Conical
Waveguide 'W2'
Node=5=6
STh=771.4cm2
SMo=1258.6cm2
Len=44cm
Conical
Waveguide 'W3'
Node=6=7
STh=1258.6cm2
SMo=3021.8cm2
Len=26.5cm
Conical
Duct 'D1' Node=3=8
Radiator 'RS1'
Node=7
SD=3021.8cm2
Radiator 'RS2'
Node=8
SD=158.4cm2
