I have gone through several amps namely INTER M , PSSAUDIO french amps etc.
Inter M korea amp manual claim 1000WRMS output @ 700VA max ac consumption , is it possible , Secondly PSS audio on their website claim that 1000WRMS amp can be powered by just 750VA rating transformer, then u can imagine from where the remaining 250 W are arranged.They simply states that they rely on large filter capacitors. Is it suffice.
WHEREAS, In our amps for 1000WRMS output the transformer is rated at 1800VA with max consumption is 2200VA @ 230VAC. With 60000MFD total filter capacitance.
PLZ give ur conclusions about these misconceptions.
rms applies to voltages and currents
from what i have learned in school, true power or simply power, is a product of rms voltages x rms currents, and the product of which is watt average...
i do not know how or why rms is still applied to power....
in manila, you will see local fabbed amps using 2n3055's running off 50 volt rails claiming a power rating of 1000watts, figure this one out!!!
Not exactly.
RMS voltage is the equivalent DC voltage, which applied to a resistive load would result in the same dissipated power as the original AC voltage.
RMS current is the same for a current through a resistive load.
Multiplying the two results in VA rating, but that in itself does not imply a resistive load. In fact, it is a value which is mainly used with reactive loads.
If you load a transformer with an ideal capacitor, there will be no power dissipated in the cap, but there's current flowing, so the transformer, which has a resistive element will still get hot. That's one of the reasons transformers are rated in VA, rather than watts.
As far as output power is concerned, it's simply a question of how long your measurment period is. For continous output, I would not recommend a transformer rated at less VA than twice the output power of the amp. Remember there's power dissipated both in the loudspeaker and the amp.
For home use, that's of questionable value, since very few run their amps with continous tones. Any music worth listening to has considerable variations in amplitude, and so should work quite well off of the caps and the fact that the transformer won't suffer from a few seconds of excess current, if it's allowed to "rest" inbetween.
For disco use with drum'n'bass or jungle or something rather more monotonous I would recommend 3-4 times the output power as transformer rating (or changing music😀 )
Rune
Rune
amp_man_1 said:I have gone through several amps namely INTER M , PSSAUDIO french amps etc.
Inter M korea amp manual claim 1000WRMS output...
1000 watts for a while, not stated how long though....
It is common practice to use a transformer with a
VA rating ~ 70% of maximum rms output power.
On continuous sine wave testing it will overheat,
but on music program it will be fine as the peak
to average ratio of music program is 10 to 20 dB.
So driven hard into clipping on music program average
power of a 1kW amp is unlikely to exceed 250W.
🙂 sreten.
🙂 sreten.
🙂 sreten.
Slightly off-topic here, but this issue disurves a good rant:
Not so true with nowadays 'pop' cd's, they are dynamically compressed, and the peak/average ratio is often 6dB or less! There's a loudness race in the (pop) music industry, where every year levels are pushed closer and closer to the maximum by the use of dynamic range compression. Which means that a Britney Spears CD from 2000 can be louder than a metal track from 1985. And an orchestra playing at full belt (over 100dB peak SPL!!!) is quieter than either, because classical music CDs haven't entered into this loudness race...
Not one to disagree with the hideous use of compression nowadays.
However 6dB range is the realm of lift music and bass channels
in (poor) live PA rigs, 10dB is a better estimate of "pop" music.
🙂 sreten.
🙂 sreten.
hi
i just gave a dose on this subject in that desi thread t/s parameters i am copying and pasting from there as it deals on this directly -
what i have found out about these firang amps speacially PEAVEY
and then copying and pasting the entire thing i wrote other wise these firangs will start arguing - have to show them our level from the begining i guess !
this deals with ure subject
1) dealing with rms sine wave output
rms output is mostly specified in pro audio
my experience
peavey mentions rms output @ 1 khz (vocal range)
this has a lot of limitations as the max load on the amp and power supply is on when pushing bass
more often than not a peavey amp
rated at 1000 w rms @ 4 ohms bridged @ 1 khz
is actually somewhere around
500 to 600 w rms (bridged) @ 20 hz to 20 khz
this will be printed in their catalogue too but since its such a fine print quite a few over look it
there are pro audio amps like the crest audio pro series which do not fall in this category at all
summing up one should go for the rms - sine wave rating
@ 20 hz to 20 khz
and it may be deceptive when going by 1 khz ratings
the entire thing (had to do with pmpo ets)
ref wattage
what to look for prior purchase
the following are the fine print i have often noticed regarding wattage
firstly wattage
there are in a broad base 2 types
1 - rms output with a sine wave input
2 - rms output with a music power input
other than high end audio i have found more often than not - music power output is the common source of rating
music power output is not PMPO
music power is often 1.5 to 2 times the sine wave rms output of an amp (depending on the class of operation and output stage)
my experience
@ 20 hz to 20 khz
2) music power rating
this has quite a few standards IEC 1 to 4
details are avalable in various sites
-what i have summed up along with personal experience is :
wattage rating has been very liberal when rating home theatre amps
even with amps supporting THX logo
what i have found is that mostly 1 transformer supplies 5 channels :- the current sharing is of concern
at any given moment where the main speaker woofer pulls high current
another channel may clip due to most of the current being taken up by the main speakers
clipping is of concern to all amp manufacturers as it will inturn destroy expensive speakers
to avoid clipping these amps have a high speed input to output comparator circuit and when clipping is detected the input is compressed automatically to avoid clipping
in turn limiting output to the speakers
there are ways of counteracting the above effent (by inguniesly placing reservoir caps along the speaker and power supply signal path and aid current sharing , which i have found most companys using) - yet the wattage rating always fall short when all channels are driven
they play loud but a better quality is achieved when pwoering the same set up with discrete amps
PMPO misleads people and is banned in most countries
i dont support it and am waiting the day when its banned in good ol India too !
suranjan
my experience
@ 20 hz to 20 khz
ref wattage
firstly wattage
my experience
@ 20 hz to 20 khz
suranjan
To complicate the matter, there appear to be more than one way to declare the maximum output:
1. Watts = [Vrails/(sqrt(2)]^2 / Rnominal 🙄
2. Replace Vrails with actual peak at clipping, usually 3-5 volts below the rail thus a lower figure.
3. Replace Vrails with voltage corresponding to the claimed THD+N figure resulting in a still lower rating.
The first is just arithmetic and even if factual isn't to descriptive of actual performance. No. 2 is a little better since it recognizes we are not in an perfectly efficient world. No. 3 comes is the one I prefer if only because it contrains the advertising copy writers at least a little.
Anybody else here old enough to remember IHF Music Power ratings?
The "power wars" of the late 60's and early 70's led to an industry standard method of testing that accounted for the dynamic nature of music, and the economics of using capacitors to suppliment power supplies for transients. The end result was power ratings much higher than pure RMS numbers, yet less than the absurd "IPP" (Instantaneous Peak Power) numbers being published by cheap Chinese audio companies.
I think most hifi buyers equate RMS to "continuous" power, and expect it to be the power you get when applying a sine wave. In that context, you can't get 1000 watts from a 750VA power supply. The only "cheat" I can think of is that you won't get full power to both channels of a stereo when both are driven together. One channel could be 500 wrms, but not both at the same time doing 1000 wrms. If it's a mono amp, they're lying.
Ah yes, Good old "music power". I think you still find it in some of the "multimedia" systems that are sold for PC's.
They are not misconceptions. As sreten explained, there are very valid reasons for sizing transformers like this.
Tim.
maylar said:I think most hifi buyers equate RMS to "continuous" power, and expect it to be the power you get when applying a sine wave. In that context, you can't get 1000 watts from a 750VA power supply. The only "cheat" I can think of is that you won't get full power to both channels of a stereo when both are driven together. One channel could be 500 wrms, but not both at the same time doing 1000 wrms. If it's a mono amp, they're lying.
Sorry but I disagree.
Hardly any domestic audio amplifiers are rated for full
output by sine RMS testing continuously for over an hour.
Output is usually equivalent RMS value of the
clipping level into a specified load resistance.
A 1kW amplifier can easily use a 750VA rated power supply.
🙂 sreten.
they laughed when I said:
The best and easiest way to acurately measure power is "thermally".
sam9 said:To complicate the matter, there appear to be more than one way to declare the maximum output:
2. Replace Vrails with actual peak at clipping, usually 3-5 volts below the rail thus a lower figure.![]()
The first is just arithmetic and even if factual isn't to descriptive of actual performance. No. 2 is a little better since it recognizes we are not in an perfectly efficient world. No. 3 comes is the one I prefer if only because it contrains the advertising copy writers at least a little.![]()
"The best and easiest way to acurately measure power is "thermally"."
You were not, by chance, a "tube guy" once were you. I worked for a RF tube manufacturer once - big, heavy ceramic and copper monsters. I had been there a while when someone explained that the power ratings were for heat dissapation not power output, and further that if you wanted to develope a higher power from an existing design you started by making the heatsinks larger, then for the next step up you would specift forced air cooling and finally desighn a water jacket to get more power still. The internals, filament, grids collectors didn't change.
sam9 said:"The best and easiest way to acurately measure power is "thermally"."
I used to warm my coffee and donuts over what was called a "barefoot linear" by Heathkit -- working 20 meter CW at 7:00 a.m. in high school. We used a broadcast power supply gifted by some alumni (yes, it had mercury vapor rectifiers).
I think that Eitel MacCullough (sp?) had already changed its name by then!
maylar said:Anybody else here old enough to remember IHF Music Power ratings?
The "power wars" of the late 60's and early 70's ...
[SNIP]
That power war is still not over. The box of my 25 bucks PC speakers stated 250W RMS
But anyway power ratings are somewhat silly for amps. It just indicates some “scale”. What finally counts is how many distortionless dB SPL can I get from my speakers.
But if my 50W amp is capable of spitting out really 50W RMS sines continuously for an hour it tells me something about its reliability.
Cheers 😉
"I think that Eitel MacCullough (sp?) had already changed its name by then"
That's the place. As recently as '91 MacCullogh used to stroll in the front door to talk to the old-timers. As in inspiriation to DIYers, they started the company (possibly in desparation) in the depression because their "real" business a STutz-Bearcat dealership went broke. They were Ham hobbiests and started selling transmitter tubes to other hobbiests. They only expected enough income to keep them from starving until the economy turned around. Then one day some guy from the Navy strolled in and . . .
On this i dissagree, an amplifier cant produce power , it is used to modulate the power supply with the input signal to get a resembling signal at the output at a larger voltage swing. You will never get more power out than You supply. On the other hand i´m fully aware of good amps dynamic behaviour, the Nad 3020 of late 70´s played music louder than most contemporary 100w rated competitors. It was still rated at 20W wich was a slight understatement, measured around 30W at 8 ohm load. But in a DIY context it would be better to keep as close to fact as possible.A 1kW amplifier can easily use a 750VA rated power supply.
If were not talking continous power woldn´t it need different power rating for each record?
Lying around somewhere here there´s a pair of JBL computer speakers with built-in amp rated at 100W, they were supplied with a power supply giving 12V 1000mA = 12W minus losses. That kind of BS i find better left with massmaket peddlers.
- True Rms Power
