You can stop it:
Set Beeper Off
Press the RANGE button while turning the meter on to temporarily disable the Beeper feature. Turn the rotary switch OFF and then back on to resume.
To drop its level it would take to hack a trace and put a resistor in series to it I am afraid
Sorry I wasn't clear Sala. I meant for continuity tests.
So, there isn't any way of adjusting the level other than modifying the PCB eh? OK, so be it then...
This is the best way to show the importance.True RMS -- why you need it -- this chart from the Analog Devices/Linear Technologies LT1968 datasheet
A table like this comes in really handy when measuring non-sines, e.g. measuring power in a saturated inductor, or using MAD to RMS comparisons
FWIW, in my 45+ year career plus the same as an audio hobbyist, I can count the times I've really needed TRMS on maybe two fingers. Is it a sine? TRMS not needed. Is it something else? What are you going to do with the number? BTW, most TRMS meters won't give you the correct answer if the signal has a DC offset. They AC couple it and that won't give you the equivalent heating value. You need to make an AC and DC measurement, then do a root sum of the squares. See https://masteringelectronicsdesign.com/how-to-derive-the-rms-value-of-a-sine-wave-with-a-dc-offset/ There are a few meters that do this correctly, but not the cheap ones. So, IMHO, TRMS is good for bragging rights, but rarely "truly" needed.
UNI-T UT139B:
https://www.amazon.es/Uni-Ball-Corr...ivamente-durchgangs/dp/B079T8XMSG/ref=sr_1_10
Compare it with the Fluke 15B+ and draw your own conclusions:
https://img.mysku-st.ru/uploads/images/02/55/13/2016/06/11/2e1b65.jpg
https://img.mydigit.cn/forum/202104/04/121801luf9eh00e9aku2iz.jpg
60,000 counts with calibration certificate for a very reasonable price:
https://www.amazon.es/profesional-m...P67-impermeable-3441/dp/B06XDDKZ5G/ref=sr_1_4
