Troubleshoot USB enumeration error (DDDAC USB 1543 mkII)
Have a DDDAC 1543 mkII, assembled long ago, about 10 years. Worked fine back then.
Ten year DIY hiatus.
Fast forward to 2019, I'm having trouble with USB (PCM2707) getting recognized: USB enumeration errors.
PCB looks fine, apart from some rust on not used pads. Gave it a thorough clean, and reflowed all solder joints on non SM parts.
It gets recognized one time out of fifty. Usually after tinkering measuring live voltages on it.
I followed Texas Instruments Troubleshooting USB enumeration errors but found nothing.
Uses Guido Tent XO, measured freq with a digital multimeter, stable 12MHz.
VDD: 3,39V
USB: > 5V
Piggy-back soldered new caps on PCB underside for circled positions, just in case original caps had dried after 10 years:
attachment.php
No change.
Tried several USB cables, and different computers, same symptoms.
Tried battery power, and the hefty transformer linear unregulated PSU I use with it; same issues.
Any hints or pointers welcome, don't have a clue what to check for next.
Thanks miro1360! Will measure that.
So the usual suspect is the PCM2707? It came proffesionally soldered, it does even have mask on top of its legs.
Already have a Hecate XMOS208 TCXO coming... have a Tent XO on the DDDAC board, these have provided me stellar results on reclocking scenarios so wanted to try salvaging it.
Don't have a clue about relative precisions of Tent XO vs the Hecate, guess should be on par?
The Hecate LT also incorporates an ultra-low phase noise TCXO clock from Japan KDS. Its accuracy is 2PPM and jitter less than 0.5PS. Excellent performance can be expected from this interface for high fidelity playback. The Jitter of the final map was measured at 4.6ps
According to Guido
+/- 50ppm / Measured jitter <1ps rms
Assuming same conditions, that's a a 4x improvement, whether if that is noticeable or not...
