Trouble with phase (Vifa XT25TG30-04)
I don't know if you are aware of the time lock feature in Holm.
1. Basically, you fix the mic position on the design axis. The axis along the midpoint between two drivers is a good choice because the vertical lobe will be symmetrical about this axis. Once you set the mic on this axis, don't move it through the whole process.
2. Measure the tweeter (or woofer) as a causal impulse.
3. Then use the "last detected impulse" in Holm and measure the woofer.
By time-locking on one of the driver's impulses, you will get the phase of the drivers relative to each other. Then just export the FRDs with phase and import into PCD. Adjust crossover frequency and filters to get phase overlap through the crossover.
You don't think to mention what bass unit you are using here, which tells me that you are new to this. 😀
IF it is an 8 inch paper unit and 1" tweeter, you face peculiar difficulties with a simple filter since an 8 inch bass rolls off fast, and a fabric dome tweeter doesn't.
Most successful speakers of this style on simple crossover used a mylar tweeter. There are good reasons for this, mostly to do with phase on a flat baffle. I give an example below of how it SHOULD be done. 😎
Thank you everyone.
System7, you are correct, I am fairly new at this.
This is a 6.5'' woofer that I got at a swap meet. The cone is kevlar.
I thought that the tweeter would be good at 2,000 Hz. because of its low fs.
Should I be considering another tweeter?
Something to think about if the woofer can't go high enough.
Here would be my 1st choice, easy to work with, good price.
The Madisound Speaker Store
Thank you everyone.
AllenB is correct, your only solution for phase is to modify the order of your networks.
Looks like you are about 60-70 degrees apart. Increasing either woofer or tweeter one order would be about enough to bend tweeter phase up or woofer phase down the right amount. Otherwise decrease order by one and flip the tweeter polarity.
David S.
The XT 25 is a very tough tweeter to work with.... It has no ferrofluid in the gap, and mostly because of that (also due to its badly damped resonance chamber) its low end response can be terrible, both frequency, and phase-wise. Unless you use an impedance correction network, right before the tweeter. One possible solution is on the picture, but you still should use 2nd or 3rd order network at minimum 2 kHz. The 16uF cap on the drawing is a bit idealistic, it should rather be around 8-10 uf (max). You can also try carefully remove the resonance chamber, and fill it densely with wool.
If you have already purchased the XT25's, you can probably keep them but raise the xo a little to around 2500Hz and use an impedance flattening LRC circuit. But you are going to also have to watch out for the woofer's peaking response above 4000Hz. You may need to raise that xo order as well.
If you haven't bought them, then you might want to consider a tweeter that is more comfortable crossing around 2000Hz.
