I just finished my Elliot 3A amp. and I set the bias after raising the voltage to 120 with a variac and all was good. The first time I turned it on with full 120 volt inrush the right channel LED flashed and the minus rail fuse blew. The left channel is fine. All parts are where they belong. Any suggestions with parts to check for infant mortality? It is a tight design and I hate to tear it completely apart. Thanks in advance. Mike
