Troels TL or alternatives?
A bit of food for thought there.
Leaning towards the Asathor. Just because. Will investigate drivers, availability and shipping from (most likely) Europe.
As a side note, drivers for the Tarkus are sub AU$500 and available locally, so may need to knock a pair up in the meanwhile. I did see a single broad baffle for it online somewhere which also simplifies things.
And I was recently gifted a pair of PA speakers which have a Radian 450 and McCauley 12" woofer - the woofer has water damage, but the CD looks good.
microdub,
One bigger bass cabinet and a smaller mid-tweeter box on top of that is not a bad thing. My recent build follows the same format, and moving around the cabinets is easier vs one big cabinet. 🙂
Just be careful with the part number for the Vifa: the local Oz product:
https://www.wagneronline.com.au/vif.../speaker-drivers/audio-speakers-pa/976455/fl/
is noted as a replacement for the DX25TG05-04 , but the original tweeter for the Tarkus is the DX25TG09-04, since replaced by Vifa the 59-04 . Paul has crossovers for both. The only difference between the two XOs is the value of a shunt resistor in the tweeter circuit, but it is important.
Not sure how different the 05-04 would sound to those tweeters, but I suggest asking the question here; or, just order the right part number from whoever has it. It's not a big part of the cost. I've only read good things about these speakers.
There have been several Tarkus builds using one cabinet, there are two on the Tarkus web page, they look great.
Geoff
Naturally you want to know that it's voiced the same as the original but at the end of the day, if you take charge of the cross and EQ there is an underlying acoustic character which isn't affected by changes like that.
