Tripath or Hypex Guitar amp designs?
Are there any guitar amp designs based around the amps that are compared to SETs, etc.
I thought any tone desires could be handled in the preamp and more carefully controlled if the power amp is less quirky.
I have not done much in terms of instrument DIY, if anyone knows of what criteria are used in selecting cabinet drivers.
I was more interested in how to get the right tone, and if it was possible with any Class D modules.
I know the typical solution would be to use a tube preamp and Class D power amp, but I was wanting to do it all without using transistors or tubes.
How about just a black box approach. I know there's a lot of discussion about the difference in class-d verses tripath, .... amps, but sound wise they're more alike than they are different. Overall very transparent, efficient, and reliable. Good "tone" in would be good amplified tone out.
Now "transparent" and "guitar amp" usually don't go together. Electric Guitars usually need a lot of signal enhancing to sound good. So just add signal enhancing ahead of the class-d to get the good tone you want.
dalcorn said:
would it be possible to do a PWM preamp that produced the desired tone?
Are you confused, or just confusing me? 🙂
As has been suggested, consider putting a published guitar preamp design in front of your Class D power amp. There are so many out there you can just pick whatever suits your fancy, here is a commonly suggested one:
i'd like to avoid the cost of such a premade amplifier
i'd like to build one of the many tube preamp designs for a guitar or bass amp, but think the cost of parts and high voltages are quite a consideration. i suppose many will tell me if i hear the difference between the two i would be willing to pay the cost difference in a heartbeat?
