I'm trying to use the tripath 4-channel amp from audio digit in my car, directly above the radio receiver. It causes a lot of inteference to the radio reception.
Is there anything I can do to solve this problem?
Say, putting the amp into a metal box or the like?
thanks
thanks
Move it far away from your radio.
Does the amp use air core inductors? If so, try switching them out for toroids or some shielded inductor.
Putting it in a metal box and grounding the box should help.
There can still be a lot of RF on the speaker lines. But your antenna wire should be shielded, right?
