Tripath TA3020 5 channel Amp Board
I need to make room for the next project, so up she goes...
There are extensive mods for these boards listed here and this one has NO MODS DONE - completely stock.
I am keeping the tranny at the moment.
Best offer gets her.
I have completed the Overload Resistor mod (won't shut down on a 4 ohm speaker load), and replaced the crappy 2.2uF electrolytic input caps with nice Bennic 2.2uF Polypropylene caps.
How's $80 + shipping?
Just like having 5 UCD180 amp and power supply modules...Just add your toroid...
With 60V rails, 300 wpc@ 4ohms.
The 500 - 600VA toroid that came with the unit has 5 wires - 84VCT and 7v-0 on the main plug (gets you +/-58V rails and the required 10V) and there are two smaller plugs on the toroid , only one of which is need to run the amp board - I beleive its 5v-gnd-gnd-12v. I will have to check right quick on this.
The third plug off the toroid onto the PS board powers another section - preamp or DAC? and not required to get the amp board running.
I believe the only voltages needed are main rails (+/-35V to +/-65V), a 10V and a 5V, i think they both need to be reference to main rails.
From the TA3020 datasheet (google it for full copy)
GENERAL DESCRIPTION
The TA3020 is a two-channel, 300W (4Ω) per channel Amplifier Driver IC that uses Tripath’s proprietary Digital
Power Processing (DPPTM) technology. Class-T amplifiers offer both the audio fidelity of Class-AB and the
power efficiency of Class-D amplifiers.
APPLICATIONS
Audio/Video Amplifiers & Receivers
Pro-audio Amplifiers
Automobile Power Amplifiers
Subwoofer Amplifiers
B E N E F I T S
Reduced system cost with smaller/less
expensive power supply and heat sink
Signal fidelity equal to high quality Class-
AB amplifiers
High dynamic range compatible with
digital media such as CD and DVD
FEATURES
Class-T architecture
Proprietary Digital Power Processing technology
“Audiophile” Sound Quality
0.02% THD+N @ 50W, 8Ω
0.03% IHF-IM @ 30W, 8Ω
High Efficiency
95% @ 150W @ 8Ω
90% @ 275W @ 4Ω
Supports wide range of output power levels
Up to 300W/channel (4Ω), single-ended outputs
Up to 1000W (4Ω), bridged outputs
Output over-current protection
Over- and under-voltage protection
Thermally Enhanced 48-pin DIP (dual-inline
package
GENERAL DESCRIPTION
APPLICATIONS
B E N E F I T S
AB amplifiers
FEATURES
High Efficiency
95% @ 150W @ 8Ω
90% @ 275W @ 4Ω
package
Any trades? hehe...
Whatcha have? My current bug is Class A amps.....
