I have a Feliks Elise amp. It uses 2x 6AS7G (6AS7G is a double-triode) as power tubes, so 2 triodes for each channel. These 2 triodes are wired in series. I bought some 6C33C, which are single triodes.
I want to make some adapters so the 6C33C will work. How exactly should I wire the pins?
Should I wire the 6C33C cathode pin to both 6AS7G cathode pins or only one of them? How about anode? How about grid?
/Mathias
/Mathias
