Trimming resistors
Hello all,
I'm looking for a way to change or trim the value of a metal film resistor. Is this doable? By how much can you adjust the value?
I suppose you can trim a resistor only one way, up or down (if at all).
Any input is very welcome.
Thanks,
Jarno.
One method is to put a slightly higher value in and then parallel a much higher value to 'trim' the final value.
Rx = 10 K.
install a 12K resistor and then add:
56K 60K 64K to get,
9.8K 10K 10.1K.
(this will add a litle bit of extra capacitance to the circuit)
If you are talking about removing the outside layer of one resistor then I believe you can only go up in value.
