I want to st up a system using an active crossover working around my Mordaunt short Festival II. I would like to bandbass the DSB208 in my My mordaunt shorts. For tight bass I would like to use my Goodman 12s that are almost identical in appearance to the DSB208 mid woofer. I would like the Goodmans 12 in a sealed enclosure that does not have to go very low because I will be supported by my subwoofers that can handle everything below 100 hz, I want to know the best enclosure size for the Goodmans 12 and the best frequency between the DSB208 and the 12. Thanks
