TRF SMD3000.1
good day everyone! I have this amplifier that has damaged switching! mosfets have the code H1 and the power supply diodes have the code S1 and S2! do you know what it corresponds to or can you give me a site where you can check? Thank you and good job to everybody !! Sorry for my english
I don't have any definitive information and you should wait for someone who does but... The markings you're seeing are produced by the amp manufacturer to prevent you from knowing the original parts. This is common on the amps made in Brazil.
The Brazillian amps use the IRF1404 in the power supplies in a LOT of their amps. For the outputs, the IRFB4115 may be a possible candidate.
