Trends Audio TA-10: Modding Potential?
Okey maybe someday i will try them 🙂
How about remote control i would like to have that to my modded mardis amp 😉
Is it easy to modifie it so i can use remote control?
Or maybe there will be a remote control for the trend pre amp?
Best Regards David
robert1325 said:
Hawthorne Silver Iris Open baffle drivers 😎
www.hawthorneaudio.com
They are very easy to drive , go very loud and sound live ! Smooth highs, very nice full mids, and fast punchy low -end...
The soundstage is deep .
What feeds my trends ta10? A bolder modified squeezebox.
Don't worry about your english, my english is not the best either!
Hi Robert, and the power supply for the TA10?
to regulate 12V-3A or increased ?
Input Caps
sts9fan said:
What do you guys think of Auricaps 2.2 450VDC and Blackgate STD 16v 2200uf for replacement caps?
I have used Auricaps in any number of applications and they are my capacitor of choice for upgrades in signal path applications (coupling and crossovers). I use the 2.2 MFD caps in a modified SI T-Amp and IMO, there is a marked improvement in the overall sound. Auricaps are offered as input caps in one of the AudioMagus modification kits designed by Michael Mardis. I feel comfortable recommending Auricaps.
I have not tried the Blackgates for the power supply, nor do I recall anyone posting that they had. If you opt to do so, please, post your impressions.
Re: Input Caps
They're expensive but were one of my favorites for coupling cap use too. They're tiny compared to these Obbligato caps. I also found some 50-63V MKT film caps to sound very good and are much smaller and cheaper to boot.
Hello ,
I need some help hooking up a pre amp to the trends.... I think this might help the passive cap coupled output stage of my Squeezebox.
It's Greg Ball's SKpre : http://www.diyhifi.org/amplifierguru/guru_008.htm
What I want to do is use the trends as a power amp and hook up the pre boards directly to the trends ( without Interconnects)
I got a ALPS 10 K stereo pot with it, But also have my 50k PEC carbon pot from Diyhifisupply... The PEC should be better but is 50k instead of the recommended 10K ( Greg) THe pre boards have about 6db gain. Can I use the PEC?
Is this the right order?
Input RCA's trends --- Volume pot---- SKpre ---- Trends ta-10
So I unsolder the trends input RCA's and lead them to the volume pot , And use the now free input holes of the trends to hook up the SKpre directly?
Thank you for helping a complete NOOB trying to learn some simple DIY!
:whazzat: :whazzat:
How well would the trends run these monitor audio speakers
http://www.monitoraudio.co.uk/product.php?application=&range=6&product=41&area=2
Silver S1 bookshelf rated at 90db, im going for the audiomagus TA-10 SE and im worried how well it will run my speakers, my room isnt big just your average UK sized bedroom.
I have no idea how loud they will go, can I go upto having to raise my voice to speak to other people in the room?
audiosteve said:
You need an input cap. The issue in not blocking DC from the pre to the TA-10. The issue is blocking DC from the TA-10 to the pre. There is 2.5V DC bias present at the input pins of the Tripath chip. So if you use polarized electrolytics, make sure the '+' terminals are on the Tripath chip side.
Thank you for the reply
There's already input caps in the amp , not?
I'm late into this, but I think I can be found earlier or on other threads. I am a fan of the Tripath chip. I have the Super T, Charlize, Amp 3, Amp 6, Amp 5 and TA-10. I've recently added the TweaKit 3 to my TA-10 and so far after 24 hours it is just wonderful.
I have about $50K of tube amps and trusted transistor stuff from UK suppliers to compare them against.
Thank you Pano for supporting this effort. I would be glad to provide any of my experiences with anyone who's interested.
Keith
