Oh, an I have also tried all possible settings of the check boxes beside Start Area, End Area, and Taper Ratio.
Ah.. its something to do with the Length Unit.
I get the error if I use centimeter, but not if I use meter. (In settings -> units)
Just need to find the bug now...
While I'm thinking of it, it would be nice if one could engage the split line while the right element is selected. As it is, the left element must be selected to engage split, a non-obvious behavior.
Just to be clear, I mean that split should be accessible from either of the left or right elements.
I have uploaded a fix for the unit bug.
I'll have a look at making it work for right elements too. Later this week....
is it me ? i have no clue how to use the software. does someone has like a small how to ? the driver spec i get ofcourse, but the drawings dont branches stuff >? how do i moddel a transmisison line for a certain woofer?
The 'Redo' will go 'round the circle, past the last change and produce the original file loaded. You can undo it back to where you were, but it's weird. 😉
I can't get this to reproduce at my end. Could you describe how/when this happens..
Thanks, gone take a look right away 🙂
and tanks for putting in all this effort in making the software!!!!!
Hope you get on ok, give us a shout if you need any help...
- Design & Build
- Software Tools
- Transmission Line Modelling Software
