Hey Guys,
Iv'e got an amplifier PCB here,from a long forgotten amp/reciever. It's missing it's NPN drivers,and output transistors,but still works,IIRC. (pulled the NPN's out for use in another project.)
Somewhere around 100W per ch. I think.
I'm wondering if I can replace all the drivers and outputs with different types,which I have on hand,inorder to get it working again.
Original transistors are:
PNP's
2SA1301 (output)
2SA1011 (driver)
The mating,but missing NPN's,are,I assume:
2SC3280 (output)
2SC2344 (driver)
Can I replace them with these? :
PNP's
2SA1101 (output)
2SA1111 (driver)
NPN's
2SC2581 (output)
2SC2591 (driver)
Would that work?
PNP's
2SA1301 (output)
2SA1011 (driver)
2SC3280 (output)
2SC2344 (driver)
PNP's
2SA1101 (output)
2SA1111 (driver)
NPN's
2SC2581 (output)
2SC2591 (driver)
Would that work?
Here are the specs:
2SA1301: HiFi-NF-E, 160V, 12A, 120W, 30MHz
2SA1011: NF/S-L, 180V, 1,5A, 25W, 100MHz
2SC3280: HiFi-NF-E, 160/160V, 12A, 120W, 30MHz
2SC2344: NF/S-L, 180/160V, 1,5A, 25W, 100MHz
2SA1101: ?
2SA1111: NF/S-L, 150V, 1A, 20W, 200MHz;
2SC2581: NF/S-L, 200/140V, 10A, 100W, -/2,8µS
2SC2591: NF/S-L, 150/150V, 1A, 20W, 200MHz
Are you sure about the 2SA1101? Can’t find anything about it.
/Hugo
2SA1101: ?
/Hugo
It worked nicely!
The amp actually sounds pretty good too! (after a little tweaking)
I'm listening to it right now
There's some rambling about it here:
http://geek.scorpiorising.ca/GeeK_ZonE/index.php?topic=1618.0
- Transistor subs..
