Transistor help for Sony STR-6120
I am not sure if this is an easy question or not, but I am looking for transistor replacements for the power amp board on a STR-6120. I tried google for cross reference guide but all I could get were NTE parts. Has anyone worked with this board before that has suggestions? I have intentions for a shotgun of this board due to serious heat damage to nearly all the resistors and caps, my guess is the transistors are dead too and if I am pulling them I might as well replace them.
2SA527
2SC631
2sc633
2SC756
CH-1256H
Any help would be great.
Roy
Find the data sheet or the transistor's characteristics...you have the package type
Example: in attached pdf find the 2sa527 and use digikey search feature for transistors that match
That is the best one can do with really old parts
good luck
Considering the difficulty in sourcing these parts (I could only find one from my local supplier, 2SC756 and it wasn't cheap), I would suggest testing them rather than just doing a total replacement. This may reduce your problem to a more manageable level. Given the age of the unit, it is likely that the semiconductors are germanium and not readily available. How did the heat damage occur?
