transistor glue?
Yes it isn't glue, it is thermal compound. It is a silicone grease studied to improve thermal conductivity between the device and the heatsink. Practically it makes better thermal contact between the device and the heatsink. Always use it, but in very small quantities, well distributed under the transistor. You can get it at electronics stores, PC repair shops, and even supermarkets. Look for "Silicone Grease" or "Silicone heat transfer compound". Be aware that it isn't cheap: I payed 6euros for just 30g of it.
Yup. A bit of Canada in a jar. Amps can't overheat up here!
-Just kidding of course.
Burned fingers made the most important point. The mounting surfaces must be clean and flat. That's more important than the brand of goo you decide on. Oh yeah, it gets everywhere, and keeps coming back.
-Chris
Just somebody brings up the question :
Is there any glue, I mean real glue, for sticking smaill piece of heatsinks to some unexpected overheated components. Of couse they have to be good heat conductors but preferably non conductors for electriciity.
Yes, there are: in fact many old PC CPU were attached to their heatsink with some kind of thermal glue. I have here in front of me a CPU with that glue; also I see on my RS catalogue that there is a glue called Heatsink Glue (850-984 in my old '97 catalogue)...
I always remember that Marantz 1060 (Chris knows what) which had some transistor heatsinked with Bostik glue. Go figure...
I sat my hand down on top of a hot soldering iron about 8 years ago. Won't forget that.... :hot: :bawling: I still have a scar that runs half the lenth of the side of my hand. Lesson is don't be in such a hurry...it can set you back.
The bit about washing the heat sink compound from your hands when your done is good advise. The silicone base zinc oxide compound burns like heck if you accidentally rub your eyes.
