i have a small car amp that i opened up, and found 2 parts that look just like transformers. i just want to know what they are for, 'cos last time i checked, transformers don't work with DC
Hi
You are right, but there is high freq. choped DC driving trafos, so you have +12v ,0v ,+12v more then 20000x time a second, which is why this are so small compared to 50/60Hz ones. So this trafos do work with AC, which you can get from DC
are you talking about a SMPS?? cos this is a small chip amp (17Wrms x 4) and doesn't have a smps.
Hi
Oh ok, in that case I don't know what you mean, I should some pic if you have... Those IC are amps, that don't need nothing else but DC voltage, so no need for smps
Hi
They do a bit, but they are there so that they filter out noise that is comming from amp, so that it doesn't go into car electrical system, it filters both way I guess
Dan2 said:are you talking about a SMPS?? cos this is a small chip amp (17Wrms x 4) and doesn't have a smps.
Does your amp have high-level input? (speaker-level)
On some amps i've opened, they all have 2 little transformers on the input side to take the speaker level down to the proper input level. It's a line-level convertor built in the amp for folks with Car stereo's without RCA plugs.
this does have a high level input, but it has 100R resistors that go to 220k resistors and to the gain pots. these transformers are no where near the inputs.
So i think we have established that they are just noise filters.
thanks guys 😉
thanks guys 😉
Input filters..........I don't see that many car amps with them. You must have a good amp, most amps I see have no snubbers or filters.
Glad you figured it out. 🙂
What amplifier is it? What IC's does it use to drive the speakers?
i wouldn't say its a good amp - it was the cheapest in the shop (sansui)
the IC is kia6210ah.
i actually am going to use this in my room - its a 4 channel amp and i have a pair of AIWA bi-wired speakers that the amp will drive. only 2 channels work now - but i got hold of another amp with the same problem, so im gonna put both working stereo chips in one case.
EWorkshop1708 said:Input filters..........I don't see that many car amps with them. You must have a good amp, most amps I see have no snubbers or filters.
On the contrary, most car amps DO have them in the form of a bar core inductor. This amplifier, however, uses a simple E-core (laminated).
Perfect Example of a cheap Sparkomatic (looks to have been modified for use in a PC!):
yep it looks like that!
just thinking now i should also run my amp straight off the pc PSU- i don't need tons of power from the amp so it should work great.
Dan2 said:yep it looks like that!
Dan-
Be careful using an AT or ATX psu. Regulation is achieved by loading down the +5V line. Without that, the +12V line will read only about +10.5V. I would do these three things:
1) find the resistor that senses the +12V line, and adjust it for +13.8V.
2) Find the sense resistor for the +5V line and and tweek it to let the 12V line put out the +13.8V.
3) Find the Crowbar overvoltage protection circuitry for the +5V out and disable it. This usually involves unsoldering a TO-92-cased SCR.
Measure the output voltage on the +12V line at various loads and make further adjustments to the upper sense resistor on the +5V line, until +13.8V is reached at full load (which is about 8-10A).
One other thing- you may wish to upgrade the usually low-quality low-ESR electrolytic caps in the output sections to good Panasonic FC-series or TS-series cans. Same thing for the 200VDC units on the primary side. I would go with 330mF Panasonic TSHB units.
There are several threads in the Power Supply Forum on using pc SMPSs as general power supplies and for audio use. Check them out, as there is a ton of good advice. Let us know how this works out.
Oh wow i didn't know you could get some extra juice out of a pc psu!
well as i will be listening to my room speakers at moderately low volumes i don't think i will mess with that PSU, but i do have another project that could benifit from that! Its a car cd frontloader that i run straight off a pc PSU. i have a sub (and amp that has its own transformer) connected to it so i don't need tons of bass, but a bit of extra power would sure help.
so the resistors i have to tweak - are they variable or just normal resistors that i will have to swap with different values??
On most ATs & ATXs, this is usually a 1% resistor. Stepping back a bit, the controller chip (almost always a TL494 or equivalent) senses the output(s) by a resistor ladder (upper & lower), with the NI input of the PWM chip's on-board error amp connected to the junction of these two resistors.
For sensing multiple outputs (like +5V & +12V), the single upper resistor is replaced with two resistors, each proportioned for the voltage it is sensing, and the percent regulation desired. Since the +5V is the most tightly regulated, its sense resistor will be proportionally smaller than the resistor connected to the +12V line. To determine which is which, simply follow the traces on the pc board from the output(s) back to their respective sense elements. The first component you will hit is a 1/4W 5% resistor. This is the one you will tweek.
Depending on how you want to set this up, you could either calculate the new value for the higher voltage (now +13.8V), replace it with a pot in series with a resistor, to make the output continuously adjustable.
I would be careful about feeding a moderately high-powered chip-amp from 12V, as its undervoltage lock-out might kick in. Operating from +13.8V will make the amp much happier.
In the photo you can clearly see "L1" marked right by the transformer looking object. I would bet dollars to donuts that is simply an inductor. there is no SMPS in this amp, it runs straight off of 12V to power those IC's and that inductor is in there to help filter out noise!
PS
PC connections would have 2 black wires in the middle. those leads are +12V Ground and the yellow is most likely remote turn on!
NOT pc connections.
NOT pc connections.
Zero Cool said:In the photo you can clearly see "L1" marked right by the transformer looking object. I would bet dollars to donuts that is simply an inductor. there is no SMPS in this amp, it runs straight off of 12V to power those IC's and that inductor is in there to help filter out noise!
I don't think anyone was claiming it was a SMPS transformer.
- General Interest
- Car Audio
- "transformers" inside car amp??
