Hi !
I have seen low to medium power amps with different choices of voltage rails
My amp has a transformer with output 20+20V and it is a 40W/8ohm
I have seen other ones with same power (i.e. 40W/8ohm ) but higher voltage rails, even 35+35
My question is :
what would you prefer (once fixed the transformer power) lower voltage output and more current or the viceversa ?
Is not more important current than voltage ?
Of course I am referring only to power amps up to 40W that do not need high voltage rails
Thanks a lot
Regards,
bg
My question is :
Thanks a lot
Regards,
bg
Not possible .My amp has a transformer with output 20+20V and it is a 40W/8ohm
40 Wrms @ 8 Ohms requires ~25 V peak amplitude - so maybe with some hokey PEP rating relying on 28 V peak from the 20+20 Vac xfmr, fully charged resevoir C
but current reserve also depends on loading assumptions - many respected audiophile amps brag about doubling power as load is halved - some suppy 4x current, power to 2 Ohms vs their 8 Ohm load rating
will you ever hook up 4 Ohm speakers, or lumpy impedance speakers that may dip below |4 Ohms| at certain frequencies even with "8 Ohm" on the nameplate
if you assume evil "matched" signal to a lumpy impedance speaker it is possibe to see large multiples of the nominal current requirement - at least up to 6x
Not possible .
the voltage measured on the pc caps is about 28-29V
20-0-20 V is the transfo output not the voltage rails
I do not have the original schematic but i found this in the web
Regards,
gino
Fine, but please make it clear.
I originally thought you were referring to VAC (which is proper) but the immediate next line you wrote spoke of "but higher voltage rails, even 35+35".
The "but" particle and the "higher" reference makes it a continuation of the earlier phrase.
And here you qualify the voltage mentioned as "voltage rails".
But, of course, thanks for the clarification
But, of course, thanks for the clarification![]()
Yes you are right i am confusing sorry.
I presume that the schema is correct but i do not have the real original one
The voltage at the secondaries is about 20-21 VAC that after rectification become actually 28-29 VDC
And actually i have seen amps with similar wattage but employing transformers with 35 VAC at the secondaries
I try to explain why i am asking
Listening even at low volume some amps with less watt gives a more full range sound than amps with higher wattage.
When you raise the volume on these latter amps you never get the low end, just mid and high range.
Like as they were with a low filter engaged
This is not realistic ... you cannot listen to music this way. You will never get a realistic feeling
It is extremely frustrating
To an extreme a krell ksa 50 can have hugely stronger bass than another and cheaply built 100 W/8 ohm
So my real question is how i can read the specifications to understand if the amp is really delivering power or just starts screaming when i raise the volume ?
I think that they should specify the maximum current output without distortion or something like this
Thanks again
regards,
gino
Thank you very much indeed for your kind and valuable explanation
Is it possible from the am specifications to predict if the amp is able to deliver current ?
I remember an experience
I went to listen to a pair of huge tannoy pro monitors ... a very tough load indeed i guess
They were connected to a 250W/channel pro amp
The audition started at low volume
Then raising the volume the bass did not come out at all .... it was only mid and high frequencies ... and also not very nice
I was shocked thinking at the power ratings of the amp
Then I saw some measurements on commercial amps
There are amps that cannot deliver more than 3-4 ampere without distortion
This is very little
The output transistors are usually 150W types even in cheap amps
The main suspect for me is the transformer
It is the first and main bottleneck for current
I read of famous little low wattage amp with a very string sound
I usually listen a low volume but i would like to have a complete sound not just mids and highs, like a head without body.
if you assume evil "matched" signal to a lumpy impedance speaker it is possible to see large multiples of the nominal current requirement - at least up to 6x
I think this is the very point
so many real speakers are very far from an ideal resistive load
The low impedances are wells for the current
To find an amp that is not undersized in the ps means to go with very high price units I am afraid
Still i think that some measurements can show this behavior clearly
But i never see them
Thanks again and kind regards,
gino
Maybe the amps that can't provide more bass when louder simply don't have enough reservoir capacitance. Remember that most of the speaker current comes from the caps. So there must be enough capacitance to supply full max output current for the entire time between charging pulses, without letting the rail voltage sag too much. And also, the caps must then be able to be recharged fully by one charging pulse. It helps, for that, to have a large-enough transformer, with low leakage inductance and resistance, and capacitors with low ESR (series resistance), and thick low-inductance conductors everywhere.
I suggest the OP makes himself a cup of coffee (or whatever beverage suits him) and then sits down to read the 'reservoir cap size' thread. All his questions will be answered, in more detail than he probably wants at this stage. The length of that thread, and its occasional meanderings, shows that the answers are not quite as simple as some people think but not as esoteric as others like to imagine. It all boils down to a ripple calculation. No magic needed, just a calculator or one of gootee's spreadsheets.
Thank you very much and very interesting indeed
Speaking of ps caps do a rule of thumb exists ?
I mean, for one channel 2 x 10.000 uF could be an acceptable solution ? will they be enough ?
I will read the relevant 3d by the way. i am very interested in this issue
Thanks and regards,
gino
A very welcome suggestion. Thank you
I start reading and hope to understand something
Kind regards
gino
Agree with the above suggestions and add:
the first and most obvious limiting we find is, of course, reaching the voltage rails.
Then DF96 and Tom Gootee speak about what we find when we reach there.
There's things worse than a clipped squarewave
The ripple will appear *in full* into the speaker, because the transistor (or tube) , being saturated, behaves like a piece of wire , connecting the speaker to the rail and whatever's there.
And thirdly, we have the amplifier current capability.
Short protection usually takes the form of current limiting, which if "too loose" protects little and if "too stiff" , yes, protects better, but often sounds screechy or worse.
There's things worse than a clipped squarewave.
Personally and most of the time i listen to music at low level not to annoy neighbors
But even a low level with amps with higher current delivery the result is more complete, with all the audio range on the same level and in the end the result is much more enjoyable
The weaker amps give more mids and highs but fail on the low end, even if i listen to 1 W or so
This is quite strange but also quite evident
Now that i understand that some amps are very limited in current it would be nice that this max output current would show up in the specifications.
I do not think that the limits are in the output devices
For instance i see for the chip LM3886 a max output current of 7A
This is quite a lot indeed (i have just checked. I did not imagine a so high value indeed for a power chip)
But to output this current i think a substantial PS is mandatory
150 W types transistors are very cheap indeed
In my cheap c352 i found these
Silly that i am i bought it thinking to have quite a current
Of course is not the case. Exceptional output bjts alone are not enough
The real limitation is in the power supply and then they must put current limiting circuits to protect the weak power supply that is where the costs can increase very easily
Another wrong decision
And there is no space for bigger caps and transformer
Thanks a lot
Regards,
gino
I don't count that as low level music.............even if i listen to 1 W or so
10mW into 87dB speakers is maybe low level.
100mW to 1W is normal level into similar speakers.
High level would be 2W to 20W.
i said 1 W but maybe is really less as you say
I did not measure actually
Regards,
gino
- Power Supplies
- Transformers and current output
