I have a couple of Ultron Universaltrafo E 12 180 VA transformers. They are E-I type transformers with dual secondary windings, and the secondary windings have multiple taps:
primary: (0-220)
secondary1: (0-20-24-30)
secondary2: (0-20-24-30)
What I want: Secondaries in parallel, 20V output. With increased current capability obviously.
How do I do this? Simply connect the two 0V-taps together, and also the two 20V-taps together? And leaving all the other taps floating?
I can post pictures or provide drawings in case my description is not clear enough...
primary: (0-220)
Yeah, well, here's the thing: As it is now I'm using the transformer for a bipolar supply, each secondary winding hast its own Grätz, thus producing +/-28V DC. Since the transformer gets fairly hot, I want to feed each Grätz with its own transformer (= using one transformer per polarity).
That's why I need parallel secondaries.
