What is the best way to wind the SMPS transformers?
All primary - Secondary ?
Primary - All secondary - Primary ?
How to calculate the wire thickness needed. and number of turns for each side
Output voltage required is +/- 90VDC with 5Amp for each rail at 50 Khz
Cores available is ETD49, ETD 59
Thanks for the help
Thanks for the help
Try:
http://sziget.mine.nu/~danko/letoltes/Magnetics_design_application_notes.pdf
and
Practical Switching Power Supply Design -MOTOROLA.pdf
at
http://www.4shared.com/file/6722272...tching_Power_Supply_Design_-MOTOROLA.html?s=1
and
at
Even more than 2kW should be possible but proximity effect becomes a real problem at those frequencies and you need to be very careful. Litz wire or foil winding is probably the best solution. At lower frequency it should be possible to use standard wire and you can still get quite a lot of power through an ETD-59 even at 25kHz... ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
