Transformer Screen & Signal Grounding Issues
You either accept that charging/discharging current passing through your speaker or you fit a speaker isolation switch or relay to provide an alternative current path. You must have a current path. There is no charging/discharging if you leave output open ended during the switching.
Would resistors R13, R15, and R15 (all 47R 3W) provide the current path for charging/discharging if there were no speakers connected? these resistors are connected across the output; i.e. from the negative leg of the output capacitor to ground.
cheers,
mymindinside
