transformer readings-out of the amp
Joined 2021
i have 3 identical transformers that im trying to establish if they are ok or not
all readings are between each of the outputs and the ground wire for each tapping
these all came from NAD 3130 amps
and all the transformers are out of the casings.
Transformer no 1
TA 1 cable 1-10.7 ohms
cable 2-10.8 ohms
TA 4 8ohms switch position
cable 1- 1 ohm
cable 2- 4.5 ohms
4 ohms switch position
cable 1- 1.5 ohms
cable 2- 2.1 ohms
Transformer no 2
TA 1 cable 1- 10.7 ohms
cable 2- 10.3 ohms
cable 1- 0.5 ohms
cable 2- 0.4 ohms
cable 1- 0.6 ohms
cable 2- 0.6ohms
Transformer no 3
TA 1 cable 1- 10.4 ohms
cable 2- 10.3 ohms
cable 1- 0.8 ohm
cable 2- 1.2 ohms
cable 1- 1.1 ohms
cable 2- 1.3 ohms
i can see consistancy with the TA 1 pairs so they are ok i guess, but the others im not sure about.
cheers, paul
