Transformer power rating and Choke specs
If you are cloning it with the original 6X5 rectfier and ELC82 pass tube which runs at 250 volts DC then a 200 watt transformer will do .
70ma is specified for the 6X5 the ECL82 taking up nearly 30ma of that and a 8 Henry choke .
325-0-325 transformer is specified at a max capacitance of 32mfd and minimum series resistance of 150 ohm.
Of course if you make changes to the rectifier/pass tube then that all changes but you did say --CLONE --right ?
