Thanks guys-- I'll try more shielding/positioning tonight and reply with the results. And yes, I love the avatar-good tubes.
If you have a look here you will see how the transformers are wound without a split core
http://www.diyaudio.com/forums/showthread.php?s=&threadid=45938
Stuart
Stuart
Hmmm (no pun intended), I wonder why my trafo generates so much EMI then; I know it's wound very tightly.
Nope...otherwise moving the transformer away from the driver boards wouldn't help. This is EMI.It might be grounding problem more than RFI.
More isolation on the inputs seems to help a little. Also, my tube preamp makes some noise of its own, and the trafo EMI and the preamp noise seem to cancel each other out! I increase the volume of the preamp, and the total noise is reduced. Very weird.
