I have a Zenith Transformer 95-1837 5060CY 5246145
It is disconnected the main leads are 3 ohms
the rectifier heater leads are .5 ohms
the tube heater leads are .3 ohms
the reds are 9.5 ohms
With a bulb tester I got constant very bright bulb, nothing to the trans.
I tried hooking it up directly with a 4 amp fuse, the fuse blew
There is no leakage between the leads, none to the case
Are my readings too low?
