If you follow the lower winding's dot connection, in both cases it goes to two diodes, one feeding the 0V output for positive half-cycles and one feeding the negative output for negative half-cycles, so the circuits are identical
If you are using a bridge rectifier instead of four diodes, both of these terminals will be marked AC and can be connected to either way round to the transformer secondary
Brian
Brian
