hello, i got a silvaweld swc1000 that has transformer coupled output. does this mean i can run a dc coupled amp with it without fear of blowing up my speakers?
If the amp can cope with a DC near short circuit at its input. It is just about possible (but unlikely) that this could cause an excessive DC offset at the output.
With a transformercoupled output pre-amp there is no possibility whatsoever to get DC-offset at the output. A transformer can only transfer AC.
So relax and run your DC-input power-amp without fear🙂.
A DC coupled amplifier is sensitive to source resistance (Rs) and the output offset will change for the worse if the incorrect combination of resistances are used.
If the NFB route is also DC coupled then the low impedance of the lower leg of the NFB loop can be matched by a similar value for total Rs seen by the amp input. This total Rs includes the RF filter.
The answer to the original question is YES. If you use a volume pot at the input, then the concerns in posts #2&4 are far less.
Not necessarily a DC leak.
Some circuit designs turn ON or OFF asymmetrically. That is the components on the positive supply have a different start-up rate than the negative supply this off-set generates the thump.
My DBX active cross-over has a nasty turn-off thump.
- Analog Line Level
- transformer coupled output= dc block?
